Notification vibrations keep repeating over and over until i swipe them away.
I just updated my HTC ONE M7 to the new lollipop version (5.0.2) with Sense 6.0 and now all my notifications are endless until i click on them or swipe them away.
For example, if I am sleeping and receive an email or facebook post notification in the middle of the night, it will vibrate and then go silent for 10 seconds, then it will vibrate and go silent for 10 seconds, and on and on. This happens in the daytime too, just super annoying at night when you are trying to sleep.
I have tried to play with the new Notification settings, but the only way I can get my apps to stop the infinite vibration sequence is to turn off notifications for that app altogether and this defeats the purpose of having Notifications in the first place.
Anyone else having this problem?
Hi, welcome to Android Forums.
You could try a 'Wipe cache partition' first, it only takes a couple of minutes and doesn't affect your data or settings. I do it after every update and at intervals between updates and so far have avoided having to do a Factory Reset after OS updates.
The procedure for 'wipe cache partition' has changed slightly after the last update and is as follows :-
Switch device off.
Press and hold Volume Down and Power, release them when you see the screen with three Androids on skateboards (takes about 20 seconds)
Tap Volume Down to highlight 'Recovery', tap Power to select.
After about 45 seconds 'Android system recovery' screen will come up. Tap Volume Down to highlight 'Wipe cache partition', tap Power to select.
Wait for 'cache wipe completed' at bottom of screen with 'Reboot system now' highlighted.
Tap Power to select.
It has cleared a number of issues after OS updates for me. The only thing I noticed after the 5.0.2 update was the weather/time widget was frozen ie. I couldn't change the city and it wasn't updating. The 'wipe cache partition' fixed it.
I hope it clears your notification problem.
As a matter of interest I've only resorted to a Factory Reset once since June 2013 when I got my M7, and that was when the screen decided to do it's own thing and wasn't responding properly.
Hi, if you're still having this problem go to
Settings - Accessibility, scroll down to 'System' and make sure that 'Notification reminder' is switched off.
