mattkranzler5
Hi guys. So I had been using my Droid until it came out with Rings Extended and it was working great but all of a sudden my sounds for notifications wouldn't work anymore. That along with some other issues caused me to reset the phone to factory. So I reinstalled everything including Rings Extended and the same thing happened again. So, I uninstalled Rings Extended and I just made the "audio\notifications" and "audio\ringtones" folders to put my sounds in. They show up under the settings for selection but when I select either my custom sound or any other sound for that matter no sound comes out of the ear piece and when I receive a notification nothing comes out either. However, if I select a ringtone for the phone (non notification) both my custom ringtone and the standard ringtones sound fine. So I know its not the speaker since the regular ringtones work as well as music. I just can't hear any of the notification sounds. This is really frustrating since I just did a hard reset this morning and had to reinstall and reconfigure everything. Have any of you guys had this issue and if so or not do you have any suggestions on what to do? I don't think there is a custom volume setting for notifications or anything like that.
Thanks in advance.
Thanks in advance.
