You can make different ones for SMS, and voicemail. System notifications are in settings under sound, but for SMS, you have to be in the messaging app, open settings, and notification ringtone option is t the bottom. Hope that helps
Yes you can, download ringtone maker and you can choose a custom sound for your text message and email etc.
This app will convert different sound formats to fit your phone also. For instance if you download a .wav file from your pc and transfer it to your phone it will convert it so you can use it as whatever sound you want. hope this helps gl
