Notification vibrate
So I noticed that there is a vibrate option when receiving a notification. However, when I turn it on it still doesn't vibrate. Is there a way to make your phone vibrate when you receive text messages and emails?? Seems really stupid that they have this feature on the phone but it doesn't work. I even went to verizon and they couldn't figure it out either.
Just to ask the question, did you set vibration notification in the Messaging app itself? In other words, start messaging, menu->messaging settings->vibrate (at the bottom, under "Notification settings")?
I don't use the email app, but I am fairly certain that there is a vibration option there as well.
You need to enable vibrate both in general settings and in each individual app where you want to have a vibration for notification (ie: e-mail, messaging, facebook, etc).
Yeah I tried that, I went into general settings and vibrate is set to "always". I then went into message settings and vibrate when notified is checked. Yet still no vibrate. Do I have a defective phone or is this just a glitch in droid phones?
It sounds like you have a bad phone - this worked fine for me. All of my Android phones handled this perfectly.
I have to agree - mine does it right now...er, I mean that mine works the way intended, with no problems.
I just got a new Bionic and had this same problem. Googled the issue and found this thread. This post was spot on and I now get vibrate with all notifications.
Thanks
My daughters phone had the same issue. No matter how the settings were set the phone would not vibrate when receiving a text. She ended up taking it to the V-store and they had to download something to her phone. I don't think it was a simple update. She didn't know for sure what was d-loaded but everything worked after that.
