Help Notification Volume Decreases Randomly
opile
My notification volume always seems to be adjusting by itself. How do you stop it? It can be my notification volume for gmail, text, meebo, or the notification volume in general. Is it something that I am doing that causes it to lower? or is there a way to lock the volume?
Believe it or not, ive noticed the notification volume go down after I dial the att code to check my data. Try it, max the volume, dial the code and the notification will go down
Wow. It does do that. And I do check my data often. Are there are others things that are known to decrease the notification volume?
Mine I noticed the other day was changed and I never changed it so I am with you. No idea why or how it does it. Somewhat annoying but easy to fix so I am cool...
Did I miss something? How is this easy to fix? You mean change the setting after every data usage request?
