Help Notification Volume Separate from Rington Volume?
lexluthor
Android Expert
Is there any way to have separate notification and ringtone volumes?
From the looks of it, this appears to be an ICS limitation. I found another thread that says this was fixed in 4.0.3, but isn't the One S 4.0.3 and I don't see any way to do this.
I'm sure Sense does it a little differently, but on my Nexus running 4.0.4, it looks like they're tied together. I imagine there's a third party app (at least several dozen) that would allow you to do this. I found this one:
https://play.google.com/store/apps/...t=W251bGwsMSwxLDEsImNvbS5jYi52b2x1bWVQbHVzIl0.
Have you tried that app? I think people are saying that ICS overrides apps like that and still won't allow you to separate them.
I guess, worst case, I can take the notification sound file and cut the amplitude down and see if that helps.
THANK YOU! You just saved me a LOT of aggravation. I was able to get separate ringtone/notification volume controls on my Galaxy Exhilarate with ICS, but NOT on my brand new Moto X 1st gen with KK 4.4.4. It was driving me crazy (and I think things could get even worse with L 5.0). But since I do my own personalized phone ringtones and notification sounds all I have to do is lower the volume on the notification sounds as you suggested. GENIUS! I was wracking my brain and didn't hit on that one. THANK YOU!
