Notification volume
DDP
I purchased my first Smartphone (Samsung Infuse) a couple of months ago (I Love it) I have one small problem with it, so I thought I would check out this site to see if anyone else has the same problem. The notification volume defaults to a very low volume, several times a day I will check to make sure that it has not changed and if it has I can raise the volume back up. So, is it a software glich or is it just my phone? and is there a way to fix it?
Welcome to Android Forums, DDP.
Sorry to see you're having volume issues with your Infuse.
Let me give you the link to our Infuse sub-forums so you can post the issue in there or perhaps just look around for a thread where they're already talking about that particular problem:
Samsung Infuse 4G - Android Forums
