Chris is C00L
Whenever I recieve any notification, my phone won't vibrate at all. I can only see I got an email/text by looking at the phone and seeing the icon, resulting in me needing to constantly check my phone. I looked through the settings and I can't find anything that would cause this. It vibrates just fine for incoming calls.
When my phone is plugged in and charging, it will do the notification sound when it gets an email/text. Is there something in the settings I'm missing?
EDIT: Just fixed it. It turns out that going to the Messaging > Setting section is a different set of options than the regular Settings > Sounds, and the "Vibrate on Notifications" option is under the former. I checked the box and it works fine now.
