Help Nova Launcher + Home Button functionality
OmriAzran
Hi there Everyone :)
I'm a really annoying situation with my Galaxy S3. I would like you all to help me if you know how. Thank you.
So... When I'm using any kind of app that don't have "lights on" display function while in the app, even if it's making a call... Usually the screen display dim or turn off automatically, now the thing is when I push on "Home Button" dim or turn off...it gets out of the app to the main default page on the launcher (Nova).
Now, I know it has to do with some nova setting or even on the general phone setting but I can't find it or make it stop. All I want is when I click the button when using any app to light up the screen and won't get out of it. instead of touching the screen.
I hope I made myself clear and I hope you can help me. Thanks again :)
On nova, home always goes back to home page before doing any action you set it to. i see your problem.
How about using smart-stay to keep the screen on instead?
Thanks for replaying.
I did Google for "smart-stay" and I do have it checked (V)
It seems it did not really help then.
Any other way to bypass it or even contacting Nova?
Nova wont do it pal but look for other ways to keep screen on. U should be able to have a toggle in the pullbar to let you choose your homescreen timeout
