TouchWiz icons are horrible, I always apply ICS Theme to Nova to have a Nexus-like launcher.
You can apply/edit any icon you want on Nova, including the Touchwiz icons.
Alot of usefull features in Nova, as well as most of the other third party launchers.
As a non-launcher user, sure wish more of you had posted images. I don't know what a bad-looking icon is, or what a good looking one is, or what diff a shadow on an icon makes. The std icons appear to have a very tiny little shadow under them - they look okay to me. I just have never figured out why I should have a launcher. Guess that means I don't need one.![]()
TouchWiz is the only launcher that supports icon shadows, that's why the icons on Apex or Nova look shite.
The main reason I stick to TouchWiz is that is seems to be the only launcher to support S-Planner's full screen widget, unless somebody knows of an alternative?
I use Android Pro Widgets' calendar widget.
Nova is light year faster than TW to me.
I don't hate on Touchwiz, I was perfectly happy with it before I decided to try a different launcher to see what all the fuss was about. After messing with Nova for a few days I was hooked, I'll probably never go back.I don't know why people hate touchwiz so much. Is it some kind of nerd fad to hate on touchwiz right now?
I rather like the look of everything the way it is. Is there some tangible reason I should be disliking it?
