Nova Launcher
nope. I like the fact you can select how many rows and columns you have. Also there are separate quick launchers - at the bottom whizz it left or right and more can be added! Some widgets differ but mostly they are available.
It won't automatically start the Notes app if you pull out the stylus (which I would have disabled it I kept TW). The whole Page Buddy feature probably doesn't work.
I believe that's it. I'll keep my 5 X 6 home screen, thank you very much.
You're right. I kept reading about it and mine never did it, so I assumed it was a TW Launcher feature. Turns out I just never enabled it.
So basically, there's zero reason NOT to install Nova.
Yeh that's one of the annoying things when using Nova launcher
Also you can't select lots of the stock widgets when you use nova launcher, eg samsung calender widget is one that I noticed amongst others
I have Nova and I use the S-pen without issues. It pulls up the note pad when removed.
The Samsung Calendar widget works fine in Nova......
I have not had any differences other then some TW widgets are not available.
I really like Nova Launcher.
Lateck,
Lateck,
From what I can see you can only select the 2x1 mini calender widget on Nova
I want to be able to use the full screen large samsung calender widget (ie full monthly view), and that's just not there in the list when you are using Nova launcher.
