I would wait.. Asus announces tablets for 2012 as well as a 3G prime with GPS that really works.
New Tablets from Asus in 2012
I couldn't take it, just placed the order at best buy...
Mine shipped from BB today!!!!.....Can I get a woot woot!!!!
Who cares about the 3G model. And it will probably come with the plastic backing and then people will complain about how cheap it feels but who cares, GPS may work.![]()
If you already have a good tablet, wait. My guess is the Prime sees a rev change that fixes the gps and wifi, via a back cover design change (probably plastic window).
Just a guess, since changes cost money and companies can be stubborn like that. Must admit that I would already have a Prime, if did not have a Thrive 10". That said, if personally found the wifi weak (care less about gps), I would return it.
Though the actual wifi range of the Prime would seem an absolute, the apparent range is subjective, since depends on what people are used to, in their own environment. Some people could find the wifi fine, since not any better or worse than current devices they have used- in their own environment. On the other hand, others could find it is weaker, if their other devices performed better- in their own environment. Case in point, the Acer 500 (I had three of them to confirm) wifi SUCKED compared to my Gtablet, Thrive, phones laptops etc, in my own environment. Everything is relative as far as perspective![]()
Dude, for someone who doesn't own a prime or plan on buying one, you sure like to jump all over wifi being an issue, which I don't think it is and I own one, anytime you get the chance ! We get "your" point, the prime's wifi sucks !
I could be mistaken, but my WiFi doesn't seem bad at all. I mean, granted, I'm using my Prime in my house and in my classroom which has its WiFi routers located in the hallways and I'm getting the same reception as my Nexus... At least according to WiFi analyzer. Do we know if this is a problem with certain units or widespread? Or, am I just a fool and I'm not understanding the problem that everyone is speaking of?... Cause that's always possible.
