Root Numbers on the keypad missing!
romey2000
Installed CM7 and I've noticed that most of the numbers on the keypad are missing!
Has this happened to anyone else? Solutions? :(
Which keypad? Dialler or keyboard? Elaborate please?
Also did you do any titanium restore? What exactly did you restore?
Hey there SU, it's the android keyboard...I didnt restore anything, flashed a friend's phone last night.
It has like 4 of the numbers but the rest are absent
You can make your own at gimpsta.
However, you can download my black one from the useful downloads thread in my signature. You will also need to download the clicker apk (for settings) which is also there
thanks!
I also tried flashing the black market zip but I keep getting the following error, any ideas why?
E: Missing file:
system/xbin/12ping
E: Verification failed
Installation aborted
I think you need to go to app management and uninstall/clear updates. I tried to download it and install it without doing that and had similar problem.
Also this isn't the latest market so marketupdater.apk will update it to the latest green version so you need to remove that from your Rom.
The error means your recovery has signature verification on. You need to turn it off to flash
Dan, i tried to flash it yesterday. Removed marketupdater.apk first, but still no joy. Infact after that i lost the market altogether and had to flash gapps to get it back. Has anybody actually managed this blacked out market? :confused:
It used to work very nicely for me when it was the latest version, but I've had little luck flashing it more recently. Next time I remember/am in the mood I might try removing market as well as the updater before flashing - that worked with the Miui camera, which was fairly unsuccessful for me otherwise, so I figure it might be worth a try.
You have to also uninstall updates too.
I have had an issue whereby there was market at all.
I reflashed Rom. Booted Rom then flashed market. Last time I successfully flashed was when I upgraded to redux 1.2 late April
Just tried again Hadron, still no joy, Annoying thing is, it tells me it has flashed successfully :mad: Still i can live with green :D
Yeah tried everything Dan, updates, market updater, cleared data, cache, every bloody thing going for market still no joy.
Yes, i managed to get it loaded up following SUroot's advice. Wasn't too fussed about it to be honest and prefer the green version.
I had it on GV. I think it was that rom that gave me trouble and had to reflash the Rom.
There are a few things that should work on any Rom that just don't work on GV
