Ok...this is kinda lame...but oh well. The OC app built into EE and Aloysius is faulty. If I enable ANY profiles with ANY settings, it defaults to 480mhz for some reason. So the OC widget said 767, and the slider was at 767, but it was only operating at 480mhz. Turned off profiles and it popped right up....3.1 mflops
On the newest EE now....still 1.5 mflops at 767mhz.....
WHAT THE FFFFFFFFFF!
Any idears?
download this app: Linpack for Android v1.1.2 Application for Android | Tools
It is an easy way to see how many Mflops/s you are getting.
I am getting 2.9 flops on the newest aloysius without the OC patch installed and I have profiles turned on. Just because your main slider is set to 767 doesnt mean thats what youre running at. If you have profiles enabled and have one set to 480, say the fail safe profile, and it has actually gone into effect, it will force your speed back down to that number.
