andriodadmirer
O.D.ROM FROM ANDROIDADMIRER
THIS IS CM7.2 BASED
THANKS TO SAMMYZ AND PRIMED FOR UPGRADING THIS EXCELLENT BASE
THANKS TO TEAMFUN FOR SOME OF THERE SETTINGS
WHAT'S IN THE ROM
1.O.C. TO 883 MHZ AS YOU PROBABLY KNEW ALREADY
2. REPLACED DEFAULT WALLPAPER
3. DELETED BOOTANIMATION AND I THEMED THE SYSTEM BOOT ANIMATION
4. THEMED ROM USING UOT KITCHEN (THANKS UOT!)
5. ICS SETTINGS LAYOUT
6. *****PIE CONTROLS***** IN SETTINGS
7. I ENABLED SOFTKEYS AND EXTENDED POWER MENU IN FRAMEWORK
8. I THEMED SOFTKEYS TO LOOK MORE LIKE THEY SHOULD INSTEAD OF DEFAULT CM7 STYLE
9.EXTRA SETTINGS IN CYANOGENMOD SETTINGS
PIE CONTOLS
CALL FEATURES
ALARM
JELLYBEAN FEATURES
LED LIGHTS
"OTHER" SETTINGS LIKE 2 ADDITIONAL LOCKSCREENS SENSE 3 AND THR "RINGS" LOCKSCREEN
QUICK COPY/PASTE
ULTRA BRIGHTNESS
APP INSTALL LOCATION INSTEAD OF ONLY USING APPS2SD
INSTALL INFO
DOWNLOAD ROM
1. BOOT INTO CWM (HOLDING POWER VOL DOWN AND HOME BUTTON DOWN AT THE SAME TIME)
2. WIPE DATA AND CACHE
3. GOTO MOUNTS AND STORAGE AND FORMAT
CACHE
DATA
AND SYSTEM
4. GOTO ADVANCED AND WIPE DALVIC CACHE
5. GOTO INSTALL FROM SD AND NAVIGATE TO THE O.D.ROM
HIT YES TO INSTALL
6. AFTER INSTALL GOTO REBOOT SYSTEM NOW AND SELECT IT
THIS PART IS IMPORTANT
AFTER THE ROM BOOTS UP YOU WILL NOT SEE A LOCKSCREEN AND THE HOME BUTTON WILL NOT WORK
THE FIX
GOTO THE SPAREPARTS APP
GOTO "END BUTTON BEHAVIOR" AND SELECT
NOW SELECT "GO TO HOME"
REBOOT THE PHONE AND ALL WILL WORK
HERE IS THE ROM LINK
https://www.dropbox.com/s/qmoss0lypkklpvg/O.D.ROM.zip
sreenshots
THIS IS CM7.2 BASED
WHAT'S IN THE ROM
PIE CONTOLS
CALL FEATURES
ALARM
JELLYBEAN FEATURES
LED LIGHTS
QUICK COPY/PASTE
ULTRA BRIGHTNESS
INSTALL INFO
DOWNLOAD ROM
CACHE
DATA
AND SYSTEM
HIT YES TO INSTALL
THE FIX
sreenshots
