WoodysChick
Hi all
I'm having difficulties sending MMS messages to some contacts (although some can receive them ok.) I don't have any problems in receiving them myself, and they appear to be sent on my phone.
I have an O2 contract, and they have sent me two versions of settings. I've tried both unsuccessfully.
Tap Access Point Names
Tap the Menu key
Tap New APN
Tap Name then tap the text box and enter O2 Pay Monthly then tap OK
Tap APN then tap the text box and enter wap.o2.co.uk then tap OK
Tap Proxy then tap the text box and enter 193.113.200.195 then tap OK
Tap Port then tap the text box and enter 8080 then tap OK
Tap Username then tap the text box and enter o2wap then tap OK
Tap Password then tap the text box and enter password then tap OK
Skip past Server as this is preset as Not set
Tap MMSC then tap the text box and enter http://mmsc.mms.o2.co.uk:8002* then tap OK
Tap MMS proxy then tap the text box and enter 193.113.200.195 then tap OK
Tap MMS port then tap the text box and enter 8080 then tap OK
Tap MCC then tap the text box and enter 234 then tap OK
Tap MNC then tap the text box and enter 10 then tap OK
Tap Authentication type and tap PAP
Tap APN type and tap Internet + MMS
Press the Menu key
Tap Save
and also
Tap New APN
Tap Name then tap the text box and enter O2 Mobile Web then tap OK
Tap APN then tap the text box and enter mobile.o2.co.uk then tap OK
Skip past Proxy as this is preset blank
Skip past Port as this is preset blank
Tap Username then tap the text box and enter o2web then tap OK
Skip past Server, MMSC, MMS proxy, MMS port, MMS protocol
Press the Menu key
Tap Save
I suspect the first is correct, as they're most similar to the settings I had before experiencing any problems. Does anyone have any suggestions as to what the probelm is? I haven't performed any software upgrades since getting the phone, would that help? I haven't even connected it to the PC as yet. Someone has suggested instaling the handscent (sp?) app, but I'm not too sure how it works.
Many thanks if you can help
Tap the Menu key
Tap New APN
Press the Menu key
Tap Save
and also
Tap New APN
Press the Menu key
Tap Save
