Can you paste the settings O2 sent you here please? I'm having the same trouble since my recent ROM change, and searching gives loads of different results!Hi there,
Since getting my HTC Desire I've had problems with sending/receiving mms.
O2 have emailed the settings they think will work, but still no luck.
Anyone have any ideas?![]()
Thanks!
So they are saying to leave Authentication Type and APN Type as "not set"?Can't remember those settings sorry, but I used these ones from the o2 forum and they work!.
Settings below - GPRS WAP & MMS
Please note all steps must be completed to ensure the settings are correctly configured.
Please ensure that when entering O2 into the settings that the letter O is selected and not a zero.
When entering the following information do not press Save until told to in the instructions.
Press the Menu key
Tap Settings
Tap Wireless & networks
Tap Mobile networks
Tap Access Point Names
Press the Menu key
Tap New APN
Tap Name then tap the text box and enter O2 Pay Monthly MMS then tap OK
Tap APN then tap the text box and enter wap.o2.co.uk then tap OK
Tap Proxy then tap the text box and enter 193.113.200.195 then tap OK
Tap Port then tap the text box and enter 8080 then tap OK
Tap Username then tap the text box and enter o2wap then tap OK
Tap Password then tap the text box and enter password then tap OK
Skip past Server as this is preset as Not set
Tap MMSC then tap the text box and enter http://mmsc.mms.o2.co.uk:8002 then tap OK
Tap MMS proxy then tap the text box and enter 193.113.200.195 then tap OK
Tap MMS port then tap the text box and enter 8080 then tap OK
Tap MCC then tap the text box and enter 234 then tap OK
Tap MNC then tap the text box and enter 10 then tap OK
Press the Menu key
Tap Save
Tap your new account so a green dot appears next to it
Press the Back key four times to return to the standby screen.
What to do next
Switch your handset off and then back on to complete your settings.
The settings are now complete.
