Help O2 mms
Penfold1
Member
Hi. I have a Samsung Galaxy Portal unlocked but originally on T mobile. I can't seem to get MMS settings from anywhere. O2 don't support the phone and for some reason it won't recieve texts from Samsung. Can anybody help please?
Instructions below...
GPRS WAP & MMS
Please note all steps must be completed to ensure the settings are correctly configured.
Please ensure that when entering O2 into the settings that the letter O is selected and not a zero.
When entering the following information do not press Save until told to in the instructions.
1. Press the Menu key
2. Tap Settings
3. Tap Wireless controls
4. Tap Mobile networks
5. Tap Access Point Names
6. Press the Menu key
7. Tap New APN
8. Tap Name then tap the text box and enter O2 Pay Monthly then tap OK
9. Tap APN thentap the text box and enter wap.o2.co.uk then tap OK
10. Tap Proxy then tap the text box and enter 193.113.200.195 then tap OK
11. Tap Port then tap the text box and enter 8080 then tap OK
12. Tap Username then tap the text box and enter o2wap then tap OK
13. Tap Password then tap the text box and enter password then tap OK
14. Tap MMSC then tap the text box and enter http://mmsc.mms.o2.co.uk:8002 then tap OK
15. Tap MMS proxy then tap the text box and enter 193.113.200.195 then tap OK
16. Tap MMS port then tap the text box and enter 8080 then tap OK
17. Press the Back key
18. Tap Access Point Names
19. Tap the dot next to your new APN until a green dot appears next to it
20. Press the Back key four times to return to the standby screen.
thanks Michael. Unfortunately no luck. There are some further options though:
MMC set to 234
MNC set to 10
APN type set to internet
Authentification Type set to normal (PAP)
are these correct/do they matter??
web browsing and texting works fine, just pictures that won't work. Any ideas
thanks again
"APN type set to internet"
Mine says "Internet + mms" - this may be of note! MCC / MNC are the same as yours, authentication is "none."
As an aside, this is the Galaxy forum, not the Galaxy Portal forum. Different phone.
