johnpjackson
Not that this would be practical to enforce, but, couldn't you make the Note 7 guaranteed not to be able to self-ignite if you fully discharge the battery? I would bet money that a fully discharged battery, even directly short circuited, would be able to generate enough heat to even be noticeable, let alone create a hazardous condition.
Of course, there's no way to instantly discharge the battery (other than the short circuit flaw that results in this whole overheating, bursting, and bursting into flames debacle, of course). So, aside from having to change the rules that have been made completely banning the Note 7 from being flown, etc., if you wanted to make your Note 7 safe to fly, or ship back to Samsung, etc., you'd have to let it run until the battery was drained. And then, boot it another time or two until it won't even power on at all.
That would work, wouldn't it?
It's not a matter of hoping it doesn't burn. The whole reason a battery can create heat at all arises from the fact that it chemically stores potential energy that is dissipated in the form of electrical energy when you complete an electrical circuit with it. When all the chemical potential energy has been dissipated, it really is accurate to say the battery is 'dead'. It means there's no more chemical potential energy remaining in it. If there were, it wouldn't be 'dead' and could keep powering your device until it was.
