thethreelaws
Member
UPDATES:
* Second Glitch Found (point 3 in this post)
* My video showing these problems happening
* Now there's a poll for these glitches.
* Temporary work-around (use 3rd-party virtual keypad)
Original Post:
Oh, boy....this one is so odd that it's sort of hard to explain without having you actually see it, but I will try...
I discovered today that my brand new Bionic (which I just bought last night) has some kind of glitch when typing into some text fields while in landscape view.
I am not certain yet whether or not this happens elsewhere, but my experience with it was while attempting to type e-mail configuration details into the relevant fields in the built-in e-mail utility.
Specifically, while entering 'domain\username' into the username field in the configuration page for setting up a connection to an Exchange account, it somehow adds an extra character on by duplicating the character I just typed when going from the 'n' in the word 'domain' above to the '?123' key (which is necessary to get to the '\' key, which is further inside of the 'shift' key screen.
So, by typing normally, the field should end up like this...
domain\username
However, since it duplicates the character that I typed immediately prior to pressing the '?123' key, the field actually ends up like this...
domainn\username
I tested this a number of times, and in different fields and found the same problem. It did not necessarily happen every time in every field, and it seems like it only happens once per 'visit' to a given field (i.e., once it happens the first time during a given 'visit' to a particular field, it won't happen again during the rest of my typing in that particular field on that 'visit' to it), but it is definitely predictably and immediately reproducible.
One more odd thing is that it only seems to happen while typing in landscape view, and not while in vertical view.
Has anyone else experienced this yet?
Is it a glitch or a feature (yeah, right!)?
Does anyone have any idea what the h3ll is going on here?
Thanks
[On another note, I was (and still am) having trouble with setting up e-mail accounts. So, while I was doing that whole, long and drawn-out troubleshooting session (well, it was many hours today), I actually typed the passwords out in a different field first, 1) to make sure that I was typing it correctly, and 2) in order to copy it and then paste it into the password field (by the way, neither had any effect). Anyway, I was able to determine that this problem of the extra character getting in there from pressing the '?123' key was not causing the password to be entered incorrectly. I'm just mentioning this for the sake of building a bit more of the freakin craziness I've been going through with this d@mn thing.]
Original Post:
domain\username
domainn\username
Thanks
