Help Odd reboot problem
UKNewbie
Member
I have just bought a secondhand HTC Desire HD
The only problem I have encountered so far is that every time I take a picture the phone switches itself off!
Any guidence would be appreciated
Hurrah, I have found a solution
[Q]Camera restart phone - xda-developers
Re. camera restarting phone - it's been reported that when on autobrightness, the camera will reboot the phone sometimes. Using an alternative camera app (like Camera 360 for instance), or not using autobrightness for the display, will help.
I have turned off screen autobrightness in Display settings and it seems to have solved the problem
Thanks for coming back and sharing the solution... hopefully, if anyone else comes looking for an answer, your posts will help :)
When the battery is "low" this can happen. And an original battery will be getting quite old now as well. Maybe a new battery or make sure it is almost full when you take pictures.
Search through the custom rom section for the DHD on xda and you'll find quite a few comments.
Dave
I have just bought a new battery
I will turn back on auto brightness and see if it has fixed the issue
Yep! That has fixed it :)
