Help Odin 3.09 does not have PDA
You should only flash the correct firmware for your CSC code, as explained in #1.1, #1.5, #1.6 and #1.7 of the Jelly Bean update - Dummies Guide
but I am surprised some "My Files" still shows files from my old setup e.g. NudnikFiles.hide.
Thought they would be gone as Nudnik not on phone now.
Could using BL have caused this and should I reflash using AP?
Yes. BL = Flashing Bootloader only. Download the correct firmware for your phone and flash it via Odin as per the instructions in the links posted above. Flashing only replaces system files and, if you are rooted, will unroot you.
ironass motto... "Flash in haste... repent at leisure!" ;)
Is there no way to get a clean install i.e. only have files that are in the firmware not those left over from a previous installation?
I did do a factory reset and cache clear both before and after flashing. I also did not let Google restore previous settings.
You mean a, "vanilla", install that requires you to format the internal and external memory as described in post #1 of Firmware update problems... what you can do!
Thank you for the link.
I am reading through it all and, hopefully, will find time tomorrow to use the information.
Ironass
Thank you for your help. Now have a phone working as I wish; just reloaded the most important apps.
