Hey guys I need help
I am flashing back to stock tomo, I get into download mode and run odin with stock rom. It gets to cach.rfs and sits there forever. Is there a work around or is my phone hosed? Thanks
Did you fix your problem yet?
Give us more background info. You said you are trying to go back to stock, I assume that is stock JFD?
What are you downgrading from, what is the current state. What ROM, lag-fix, kernel? etc.
Did you use the proper pit and tar files?
Give us more info.
Sorry long night, anyway I got it fixed. After realizing I had the 513 pit file I got the 512 and it worked like a champ. Thanks
what is the difference between the 512 and 513 pit? didn't know there was a 513.
I'm not sure what the differences are, but I've seen it posted a few times that the 512 pit is the one we should be using. There are others pit's still, but 512 is it for us.
Oh...just found these:
xda-developers - View Single Post - I9000XWJM2 is out!
512 PIT/513 PIT What is the Difference - xda-developers
