Root Odin Help
XLS125
Every time I put a file into the PDA section of Odin (4.03) I get an error message saying, "Invalid Image Type". I have tried several different files and even a different computer and i get the same message. Does anyone know what I am doing wrong? Thanks for your help.
What is the name/file type you are attempting to load in Odin?
I flashed a .tar.tar file last night. Mine was the dl09. If it came from adryn it fine. I also flash dj05 which was .tar.md5
Do I download the file on to my sdcard? Then power off the power, hold down the down volume button and plug in the usb cable? When I did that, a yellow triangle appeared on my screen and at the bottom it says downloading, do not turn off target.
Or after I download the file, do I need to click on the file? For some reason it's not promting me for Odin.
Thanks
Thanks
for odin
1. make sure you have the sammy drivers installed
2. download odin, and the file you want to push to a file somewhere on ur comp you ll remember where it is
3. put the phone in d/l mode (power off hold volume down and plug in usb) you ll have the yellow triangle thing
4. open odin on ur desktop and load the file under pda
5. hit start
6. let it run
7. profit
i suppose renaming it to .tar.md5 *might* work...but personally it went through for me under .tar.tar so idk
maybe someone else does :o
