Root Odin stuck on sbl.bin
lotreaglesfan
Phone has been on sbl.bin while running ODIN3EXECUTION 1.00 for the past 5 minutes. Hoping I haven't screwed myself. I have to send the phone back to Samsung so I wanted to make sure that it was running complete stock since I rooted and deleted the Mobile AP app and such.
How long does ODIN take on this? :\
<ID:0/007> Added!!
<ID:0/007> Odin v.3 engine (ID:7)..
<ID:0/007> File analysis..
<ID:0/007> Set PIT file..
<ID:0/007> DO NOT TURN OFF TARGET!!
<ID:0/007> Get PIT for mapping..
<ID:0/007> Firmware update start..
<ID:0/007> Sbl.bin
A normal stock flash with Odin takes ~3 minutes.
The SBL and Boot files have to do with the Bootloader. This is a really nasty area to get stuck at - If your phone doesn't reboot anymore (goes black, doesn't power on), then you are hard bricked - There is no simple fix for this.
I always sigh with relief every time ODIN gets past that during the flash to stock process.
