BabyBlueJeff
I was trying to upgrade my phone before work, but it was taking longer than I thought and I had to go to work, so as bad as I didn't want to, I had to unplug it while it was upgrading (from 2.1 to 2.2). Long story short, I'm trying to restore the factory settings with Odin3 One-Click Downloader.
I was just wondering how many people have used this to restore factory settings? How long did it take?
<ID:0/005> Added!!
<ID:0/005> Odin v.3 engine (ID:5)..
<ID:0/005> File analysis..
<ID:0/005> Set PIT file..
<ID:0/005> DO NOT TURN OFF TARGET!!
<ID:0/005> Get PIT for mapping..
<ID:0/005> Firmware update start..
<ID:0/005> Sbl.bin
<ID:0/005> boot.bin
<ID:0/005> cache.rfs
<ID:0/005> dbdata.rfs
<ID:0/005> factoryfs.rfs
It got stuck at Sbl.bin (30 mins +) for a while, and now it's stuck at factoryfs.rfs.
I'm just wondering if it's really frozen or that it just takes that long? And how long does it normally take? It's taking so long that I'm worried that my phone's battery will die before it's done.
<ID:0/005> Added!!
<ID:0/005> Sbl.bin
<ID:0/005> boot.bin
