HI all
I am a keen walker and mountain biker and make use off OS maps. I have been trying a few apps out for this since getting my desire. None quite do the job though:
Maverick comes close as you can create off line maps in many formats including OS on the pc and then put them on the SD card. No signal needed in the middle of the sticks. The only issue I am having. When you record a route, if you lock the phone, it loses the track. When you unlock it, it starts from new location
MY tracks is great. Records track perfectly and upload to Google maps. ONly issue, it uses Google maps which has no off road info.
OS atlas lite. Great OS info down to street level to if needed. STreet level better than Google maps. Problems, no SD cache. No signal, no map. Also, when recording a track, big gaps between points so it looks like you have cut big corners out.
I need something like maverick that works correctly. Any ideas?
Thanks
Thanks
