Official HTC Car Kit
craggybuk
Member
Has anyone purchased the official HTC Desire car kit (reference on the HTC website is CU S420)? If so, does the charger actually charge up the phone or just prolong the time it takes for the battery to drain like all of the unbranded chargers seem to do?
Thanks in advance
Craig
If the kit you mention has the HTC micro usb cigarette plug-in with the coiled charging lead, this will quite effectively charge your phone whilst you're using it. I have the lead/plug, but am not using that cradle and it has coped with sat nav use and kept it charged.
Delivers for me :)
I invariably have GPS, Google Nav, Bluetooth and wireless on ( having forgotten to turn off the latter ) and it still charges the phone.
Using Tasker I can have the Desire automatically switch on Bluetooth and GPS when it gets docked as the cradle activates car mode.
It comes with a plastic disc with a very strong sticky pad on the back. I stuck this to the top of the dashboard and used the cradle on that. I did this because when attached to the windscreen, the phone acted like a mirror when the display was off - very annoying. The charging cable is not coiled so it is easy to tuck behind trim in the car.
The only issue I have is inserting the phone, the manual shows it slipping in easily, but I have to fiddle a bit. I sent my first one back thinking it was duff and to be fair the second is much better.
Having said all that, it is expensive and you can probably get something from mobilefun.co.uk along the same lines with a separate charger.
Hippo
I have the Brodit and it's brilliant. Charges the same as a AC adapter (1A?) so you can use Navigator and still expect it to be charging the battery. Only slight niggle is it doesn't identify itself as a car-kit so the phone doesn't switch to car-mode (and I can't switch Bluetooth on automatically). But since that was a Froyo addition I've never had it before the upgrade so I don't miss it.
If someone knew how to do the car-mode switching (without cutting into the wiring to make the USB connect properly) I'd love to know.
Hippo
That's what I've read. That it's not easy to insert, which at that price is just unacceptable...
I've also read that if you mount it on front window, it is hard to adjust it, if the angle is steeper....
Hmmmm. Not very reassuring...
Anyway, I have ordered this one:
FoneM8 - HTC Desire PREMIUM Dedicated Windscreen Mount: Amazon.co.uk: Electronics
ive been loving the thing, true getting it in does require a non "bull in the china shop" approach but its worth it know you have secured it properly. Price is worth it for when something goes wrong. i'd feel better complaining to htc that their dock broke and damaged my phone. i suspect they would entertain repairs that way rather then explaining that a
Not perfect but a workaround i use is to schedule bluetooth switching on automatically using an app named 'Tasker' at times i know i will be in the car (morning/evening commute) then within the Google Car dock app you can choose a setting so that it launches automatically when it connects to the car.
Have a look at the Brodit active and passive car docks. They fit perfect and can be installed so you see no wires etc. There are also mounts available if needed that clip into the dash and are available for most car makes and models.
Passive
Brodit Passive Holder With Tilt Swivel - HTC Desire - 511141
Active
Brodit Active Holder with Tilt Swivel - HTC Desire - 512141 Reviews & Comments
Proclips
Brodit Proclip | UK | DSLDevelopments
Hope this helps mate.
Interesting wording on one of those:
It's right there when you need it and it's always in an upright position for better reception.
Better reception when held upright? Also can't help but notice it only holds the phone at the bottom.. where the antenna is :D
Otherwise they look good though and a fair bit cheaper than the htc one. I just bought a
I find the actual charger itself (on the official HTC car charger) isn't a snug fit on new cars. it drops out fairly easily with the slightest of touches - not useless but not great.
With SatNav on it will charge the phone by around 1% every 5 minutes.
