Root ok i'm wondering and since havn't seen it asked
reapert
Member
ok i'm having issues with the dailer code ##33284# "others/ hdr/1x selection evdo only mode" i'm having the network error 7 anytime i try to set it(worst was when the shev rom had issues and i almost lost the phone compeletly) and was wondering if anyone knew of a way to fix this. i would like to try this menu option. and if your want know what the network error 7 is like "no incoming calls at all and no out going text msgs(takes a few moments to get the error to pop up sending)" from what i had happen to me. :(
not what i was asking . i've used that and i'm not asking about the other code. i'm asking about the ##33284# menu other/hdr/1x evdo only. not meaning to sound rude
If you are wanting to set the radio to evdo only there is an other way. Star settings that comes in starscrom I used it on 2.3.6 just to see if it works and does.
can you drop me a link or send it to me .i'll check back here in a few hours, other biz to take care of .
