Okay so who hates the volume controls?
I wouldn't finding a volume widget that was more of a simple slider for only volume (as opposed to some widgets that have speaker volume, ringer volume, music volume, etc).
I'm really embarassed to admit that I don't listen to much of it. What don't you guys like? The position? The responsiveness of the buttons? Is your answer going to make me mess with it and realize "yeah, that is annoying, get me that volume widget, STAT!"? :eek:
For me i have to look and see where the controls are. It seems like you need to press the exact center to get the sound up or down. Almost like my keyboard after I drop a drink on it, sticky and stiff. Okay no wise remarks :-)
Good thing there aren't any buttons on the opposite side of the tab. They would get pressed every time.
