DiagonalArg
Hey all! First post. Simple question. Hopefully not totally stupid!
Will need to root soon so I can use the TB as a hotspot for my xoom. I've stayed on Froyo to make sure I'd be able to root, but I see GB is rooted. What should I do, stick with Froyo & then root that later, or should I upgrade to GB now and then root that?
It will probably take me some time to research ROMs and get up the courage to switch, so maybe that's an argument for upgrading first? Otherwise, I'll be stuck on a rooted Froyo for a while. Also, I see rooting GB can preserve your data. Don't know if that's an argument for upgrading first or not. What data is preserved? Apps? Settings?
Thnx!
Thnx!
