xInterlopeRx
Well thanks partner...has the test file been tested yet?
No. I haven't been able to get mine fixed yet. Also, I'm working with another guy to get the vendor files right so they will def be changing.
Just a heads up the cm10.2 current build does not boot or have adb for logs![]()
Where are they working on 10.2?
since the reverb and rush are similar, is it possible for the cm build to be ported to the rush?
Eventually
you are one of the developers for the reverb and cm right?
yeah, he's one of the developers for the team working to port CM to the reverb
thanks for the answer. well i see this is hard to port to this device. does this device have an overclocked kernel or not. if so can it be used in conjunction with cm10? also is it possible to pull every file from the phone and put the necessary files in cm10?
i take it was a no go. hmm thats a shame. wait a bit, we have a stock rom right? is there a way to use the stock rom as a reference and use the stock rom as a base for cm10
