Andrewdroid
Any ideas on how to free up space without deleting apps? I really like One Click Lag Fix, I don't wanna get rid of it just for space reasons.
I was just looking using Root Explorer and there are some massive files in /data/fota. What are they? I have 3 files, fota.status, (Size 36) and fota_delta_dp1 and fota_delta_dp2 both size 62914560. That seems like a lot, I'm guessing it's measured in bytes so that'd be 60 megabytes or so, so 120 total. Are they safe to remove... seems like the results from the over-the-air update.
