I will update periodically with 2 files per available RUU. One is an exe that will do everything for you. The other is a zip file with the rom folder dissected and a bat file that will revert to stock. I am currently building these files.
WARNING! THIS WILL RELOCK YOUR BOOTLOADER, DELETE ALL DATA, AND RESTORE STOCK RECOVERY
Hope you understand the risks! Be sure to remember that this is for windows only. If you need scripts for Linux or Mac please PM me and I will build them for you. No scripts of those exist as of now. Now let's get started.
You will have to download the following files before we begin any heavy work, also, make sure your phone is charged to AT LEAST 80% OR YOU WILL BRICK YOUR PHONE PERMANENTLY.
Downloads
Java
HTC SYNC
Choose your RUU
- Virgin Mobile
- Virgin Mobile ROM Folder
You will have to disable Allow Unknown sources and enable Android Debugging in Settings > Apps. for the exploits to work. Then connect your phone and run the STOCKMEUP.exe or .bat file depending on what you downloaded, which will flash the custom recovery, as well as start up the proper RUU for your phone. It will also relock your bootloader.
Please Donate if I helped you!
Cafe Kam
