One speaker not working
clonedr
I have heard people having issues with only one speaker working. Both of mine work. To test I cover one with my thumb. Make sure mono is not set as audio type. Goto settings/accessibility/hearing/audio type and change to stereo that should turn on both speakers and give you a balance setting
If there was two speakers and one wasn't working, then changing the balance would diminish the volume, which it doesn't.
One grill is a speaker, the other grill is for aesthetics. The small hole between the charging port and non-functional grill is the microphone
On the ZTE max duo you have to go into call settings and turn off hearing aids.
