Help one way sync with oulook on exchange
Hi
since I updated to android 4.2.2 on Galaxy nexus 2, my calendar wont sync properly.
ANy entries on my outlook calendar sync to my phone but any entries I put on the phone dont sync to the outlook calendar.
The office uses outlook 10 though an exchange server.
After the update , no sync worked. Emails and calendar wouldnt sync at all
Sadly, the updates and changes to android causing apps etc not to work is a common problem
I did the full reset which caused some messing about.
After the reset, email works fine, no problems.
Calendar only syncs one way
I've looked at diferent sites but some fixes looked like adding software to the work comp which wont happen and others needed bought apps to work
ANy clues ?
