when you disable text notification to show up in status bar, it dims out the ability to have a sound alert. so my texts dont show up on the lock screen (good) but now i dont get any type of alert, (bad) any way around this?
yes stock messaging app. i uncheck it, the notification dims everything else under it. so i cant get any audio alerts for texts.
No. Not just you. I have noticed this when turning off notifications. Im using chompsms till handcent gets straightened out. Itll let you customize your notifications more deeply. I found that weird too though.
