danielevans83
Just a word of warning to people using the Soundgate M2 to mount their phone in a location in their car that gets direct sunlight. Mine was mounted at the front/top of my dash and barely sat in the sun, but since its 95 and humid here BOY it heated up quickly. So quickly that just on a 30 minute drive to get lunch the screen protector I had started MELTING IN THE CORNER. Obviously this is no way the Soundgate's fault other than making it possible to mount your phone wherever you want. Definitely mount it in a location that does not get direct sunlight in your car if you live in a hot area. I never thought the sun would actually melt anything. Good grief.
P.S. the type of screen protector I had was one of those from Ebay that uses water to apply it and requires taking the battery out of the device and letting it dry overnight. it was AWESOME (no bubbles, couldn't even tell it was on the device, no peeling corners) up until this.
