kyyrewyyoae
My wifi will only connect to one ssid after reboot. If I try to switch ssids or leave the area the wifi will not turn on until I delete or rename the data/misc/wifi directory and reboot again. Not sure what else to try here.
Background:
I rooted my Note 3 with towelroot, and was trying to change the build.prop file to change the DPI (I didn't know there were apps for this). I couldn't get it to save changes, and in trying I set the file's permissions to 777. Then I got the changes made, but didn't change the permissions back.
So reboot, won't boot. ADB wouldn't find the device, so I flashed stock to restore. And it worked! My phone booted, I was able to root and change the DPI and everything was great for a couple hours. Now the WIFI won't work at all. It hangs on "Turning on..." when I try to turn it on from settings. Thinking maybe the modem was the problem, I tried flashing NC2, NB4, and MLG firmwares. None of them made any difference. In settings < About Device Baseband is N900AUCUCMLG and build number is KOT49H.N900AUCUCMLG.
Any help would be appreciated.
Background:
