Help Only boots to clockwork...Help
jme0802
So I am running a vibrant and I have Clockwork installed. I recently flashed to Team Whiskey's Bionix 2.2 based rom. When trying to use some of the apps I got a message that said my Kernel was not compatible with that app. So I followed the help link, and tried to flash a new Kernel. There was an error flashing and now I get the Samsung vibrant logo, then black screen, then back to the same logo.
I can however get it in to clockwork. I tried to reflash the rom because it is still on my SD, but I got an "Failure on line 12". I also tried to mount sd to my comp through clockwork but that didnt work either.
I am not sure what to do next. Any help is appreciated
Thanks
Did you do a nand back up before you flashed? I would try to restore to before you flashed the rom if you did.. and instead of flashing a kernal, just try reflashing the ROM. Something just probably went wrong the first time or maybe you got a bad download. Those team whiskey roms are all pretty stable and you shouldn't have had any kernal issues to begin with.
