Help Only left headphone works?
Ryukashin
Hi,
Ok not sure if anyone else has had this problem, but every time I use headphones/speakers/anything that uses the headphone jack I notice that the sound only comes out of the left speaker and I know both speakers/headphones work fine on other devices. Is there some setting i need to change, somthing i can download to fix or what.
Thanks for any help :)
Sounds like the headphone jack is bad on the phone. You will probably need to get it replaced under warranty.
