Root Ooops... Stuck on HTC Splash [RESOLVED]
Lucidot
Not sure what I did just now, but the phone did not like it at all.
I was having radio cut outs so I decided to download the latest radio file again and reinstall it. So went into HBOOT and completed that task. Then after system loaded I went into recovery and decided to do a factory reset. I am running BAMF soab.
When I rebooted out of recovery the phone went to the HTC splash screen, and has been sitting there ever since.
Any help is greatly appreciated.
BTW - I did pull the battery and try again with the same results.
UPDATE: Problem has been resolved.
scotty85: Good point
My biggest issue was I had not removed or renamed the radio file on the SDcard. So whenever I was booting into HBOOT I could not get to the recovery to reinstall a ROM.
What I did was take my SDcard out and put it in another phone so I could delete the radio file. Then I put the card back in and was able to boot into recovery from HBOOT.
After that I installed the ROM and now this baby has been put to bed. :)
