Root OOPS broke it... not quite bricked
sorry thought that would show in sig
milestone A854
Alaska communications (same as Verizon-I think)
build ESD56
firmware 2.0.1
baseband c_01.3e.01p
kernel 2.6.29-omap1-g0dd7e0b
android-build@apa26 #511
P.S. I know what none of this means. this is the first droid I have had but still had to play with it.
thx
I am currently trying a variety of SBFs to see if any fix this but so far none have. some won't even flash. any ideas on a good stable working SBF?
OK for a rookie where do i find info on APN. i cant find anything by searching this forum?
In addition, you'll have to get the device activated on their network. I am only marginally familiar with Verizon's CDMA network, but if it works in AK the same way it does in the 48, you should be able to log in to your account online and swap the device using the EIN. Otherwise you'll have to call your provider.
no access to APNs from settings other than voice dialer.
I am now lost as to how i can store new APN. tried to modify the Verizon apn that was there but when I hit save it vanished.
