D d3310n Android Enthusiast May 21, 2011 #1 tried the boot fail method.... but i just go to cwm....what should i do from there? i am cluless. i want my nook to work!
colchiro Extreme Android User May 22, 2011 #2 I don't have a clue what you did. Need more information. What did you have installed before? What did you install now? I see you posted again at a couple hours later, did you resolve this?
V Valkerie Android Enthusiast May 22, 2011 #3 Isn't recovery where you should be doing all your flashing anyway?
D d3310n Android Enthusiast May 22, 2011 #4 Don't worry about it I figured out what to do, figured out my kernel problem to! )
D d3310n Android Enthusiast May 22, 2011 #5 colchiro said: I don't have a clue what you did. Need more information. What did you have installed before? What did you install now? I see you posted again at a couple hours later, did you resolve this? Click to expand... Yes I did,just had to reflash in cwm
