russhoopes
Not sure if you all are as annoyed as I was about links in SMS and email not opening their respective apps but rather just the browser, such as YouTube and Play Store. After a lot of searching i have found out how to change it back to the way it was before Apple sued HTC.
-First your EVO V must be rooted, I used HTCdev method and installed TWRP recovery and superuser, still S-ON. MAKE A BACKUP!
-Next you will need a root file browser and a build.prop editor, I use Rom Toolbox because it has both of the functions needed.
-In the root file browser go to /system/apps and delete the file HTClinkifydispatcher.apk
-Now using the build.prop editor find the line that says "ro.da1.enable". Click on it and change from "true" to "false"
-Reboot into recovery and clear cache and dalvik then reboot.
-Now when you click on a youtube or play store url it will ask you which app you would like to open it with.
I cannot take credit for this. I found it on XDA for another HTC phone running ICS so I tried it on my EVO V and it worked. http://forum.xda-developers.com/showthread.php?t=1696536
Hope it helps.
Hope it helps.
