5tevie
Hi Guys,
Another newbie question for you.
When I want to start my Note 10.1 I do all the normal stuff and the opening page appears. It shows 4 large icons in a square that totally cover the normal sized icons that you would expect to see. At the top right of the screen is a little icon with lots of little dots and if I hit that, the 4 large icons disappear and I get to see the smaller icons underneath.
OK, 2 questions.
Can I adjust settings or do something else to make it so that the 4 larger icons don't appear at all?
Is it possible to swap and change which icons appear on the Home screen?
Cheers,
Steve
OK, 2 questions.
Cheers,
Steve
