Installed Opera via the market ap and i can load it up but the homescreen just sits there,if i press anything on the screen nothing happens at all?
Any ideas?
Cheers
Chris
The Opera Mini browser in extremely fast compared to the default browser.
The thing is, Opera Mini 4 isn't designed for touch phones and works very poorly on Android phones.
If you try Opera on another platform, ie on Nokia phones, it is very very fast.
Opera are currently working on Mini 5 (which you can download here Opera Mini | The most popular mobile phone browser in the world) which will work with touch screens but there is no Android beta available yet. Apparently at a recent tech expo they showed off Mini 5 on Android.
You can get Opera Mini 5 to work on your Android phone but you have to install JAVE/J2ME Runner (from Market) on your phone first.
Although Opera Mini 5 the application runs slower as it's on a virtual machine of sorts (ie it takes a second for menus to pop up when you press a button), you can still see how quickly it can render website.
See here for more instructions
Haavard - Run Opera Mini 5 on your Android phone
same issue here...is there another alternative?Hello Chris --- I got similar results after installing Opera 4.2.
If I am remembering this right, look at the lower right corner of the screen and there is part of a "pad" showing. Press on that and it does come to life --- to some extent. I could not get it to work very well at all. The control features were so small, I could hardly press them. I ended up taking it out.
Not a very positive report -- possibly I was not using it correctly.
Cheers --- Bob![]()
