Opera mini restoration
archz2
Hello
I hard formatted my phone 1 month back. It was rooted and is still rooted. I had opera mini installed on the SD card. i.e. I moved it using link 2 sd application.
I have not partitioned my SD card. Its just plain fat32 formatted simple. I want to install opera mini now. Is it possible that I get all my data ? i.e. bookmarks, saved pages etc. ? I had not specifically backed up it, but since it was running from SD card, what should I do now to get back my old data?
I'm doubtful that you can. Typically those types of things aren't saved on the SD card. Despite being able to "move" over to the SD card, it doesn't truly happen in its entirety as part of the app will remain on the handset. Cache is the kind of thing that typically gets moved over there. You can poke around your SD card with a file viewer, or plug it into a PC if that's going to be easier to search/navigate with to see if you get lucky, but I wouldn't hold my breath. If you do happen to find them, do post it here as I'd love to know what file they were in.
