Root Optimal SetCPU Settings
UKCatFan
Android Expert
I am thinking about installing it today and am wondering if anyone has an opinion on what the optimal settings are for balancing between battery life and performance. On my old Optimus I ended up taking it off because it would cause it to hang with any worthwhile reduction of CPU speed. Thanks in advance.
This where I am at an not overheating and no problems I also have profiles set for charging and in call and screen off 716, 4something not sure and screen off is like 4 hundred something to
Sent from my LG-MS840 using Tapatalk 2 Beta-5
i never really felt a differece in battery life with underclocking
Thanks for your input.
On this device or another one? I probably got 25-50% more on my Optimus when I had it aggressive. That made the launcher crash a lot though. When it was not set as very aggressive then it still saved some power, but not enough to bother even using it. Since this phone has processing power to spare, I am hoping that I can slow things down to save some juice.
That's on the connect
