I forgot to do a reboot. Now I'm down to 8% awake time. Thanks for all the great tips!i wouldnt, no, what apps are you running?
I turned off notifcations on messenger, downloaded chompsms, and my awake time is still at 70-80% any ideas or helpful tips? gps off, bluetooth off, wifi is set to always on, but is switched off right now......
Stop using your phone and the awake time % will decrease. It's those stuck at 100% EVEN AFTER THE PHONE HAS BEEN ASLEEP that have a problem.
If the awake time % is dropping after the phone goes to sleep then you're fine. If not then I don't know what to say.
How can you uninstall the visual voicemail that comes on the phone from verizon? Advanced task manager tells you that it can try to remove it but it can cause problems since it comes built into the phones softwaremake sure you have all visual voicemails uninstalled (including stock verizon app) and cancel visual voicemail with Verizon. that dropped me in to the 20s.
The 2 rounds of updates coming in dec and jan will address the 3g signal being flaky i think.
6. Turn off haptic feedback for typing and touchscreen inputs (with keyboard up press the gear for settings>sound feedback and vib when typing OFF)
I thought I had fixed my "bug" with SMS and decided to try to power down last night before charging. I was at 28% and everything was fine. I turned off mobile networks and wifi before going to bed. I powered it back up this morning and checked my status and I was at 100%??? What?? Help? Am currently doing the sms fix again.
Hey guys my name is Jude. I just got my Droid Eris this past Tuesday. I loved it...until I saw how fast the battery went. I never had a smartphone so I figured this is what it did. Until I came across this site. I joined just so I could thank you all for the tips and tricks and I have put them all to good use. Just today I let my battery drain I got 6hrs and 10 mins outta it. It then took 4 hrs and 15 mins to charge. After 30 mins I had went from 100% battery to 85% and I had only made 5 calls. So I came back here and did all the tips and I will do the complet dead and then full charge for then next 3 days to see if that helps. I keep reading about an update for the Eris in December. What will this update do, how will it help/fix and will I have to get a new phone or will my phone just update by itself? Thanks so much for the help and I hope you all had a great Thanksgiving!
